I replaced water pump... Case is empty could tht b the problem just wanted to check before filling
C crazyfish73 Seaman Apprentice Joined Feb 25, 2013 Messages 37 Mar 10, 2013 #1 I replaced water pump... Case is empty could tht b the problem just wanted to check before filling
L Laddies Banned Joined Sep 10, 2004 Messages 12,218 Mar 10, 2013 #2 Re: 03 15hp merc won't go on reverse No thats not the problem, did you turn the shift rod while the unit was off
C crazyfish73 Seaman Apprentice Joined Feb 25, 2013 Messages 37 Mar 10, 2013 #3 Re: 03 15hp merc won't go on reverse Yeah had to unscrew the bottom lever and take clip off to remove the WP housing
