sportsman65
- Mar 10, 2013
- 1
I have a 1997 Force 120hp. Last year it was running good but the water comming out of the pee hole was weak. So I changed the waterpump this past week. I took it to the lake today to try it out and the waterstrem was great. But after running it for a little bit it started to skip and would not idle. I was thinking it was some bad plugs so I loaded it up and brought it home and pulled the plugs. All 4 of them had milk water on them. I started look for a cause and notced Milk water dripping out of the carbs. Started pulling water cooling hoses on the side of the block and all of them had milk water. So I'm guessing alot of water in the crankcase. I done a compresson test #1 had 120psi and #2 #3 and #4 had 150psi to 160psi. I'm thinking a head gasket. Any help would be great.
