Put boat in water to test run for this season, and steering was extremely difficult. After googling Mercruiser steering problems, I have done the following:
Removed steering cable pin past control valve and steering wheel turns very easily, held a screwdriver in cable and applied resistance and cable still moved freely.
With out drive still connected to power steering piston, I pushed the drive all the way Starboard (right turn) and the unit moved easy, tried to move the unit port (left turn) and the unit did not want to move, asked my son to try while i observed the piston and it appears that the piston was compressing the fluid and not allowing the unit to move. I reattached the steering cable and with considerable effort got the unit to turn fully in both directions. Disconnected it and tried again, when pushing it to the left it wants to return to the right. My power steering unit is the type without the quick connect hoses. Are there any other tests i can perform to be sure the the unit is bad before replacing it? Or what else can it be? Fluid in power steering pump is full, not dirty, belt is tight and pump is not making ANY noise. Steering is difficult with boat not running, idling, and at 2000 plus RPMS. Did I leave anything out for anyone to help?
Boat is 1999 Trophy 2052, 4.3 liter, A1GenII drive.
Any help would be greatly appreciated.
Nick
Nick
