2Cold2GetUp
- Mar 9, 2013
- 1
Hi, I have an early 1980's Marina 90, 2 stroke, 3 cylinder, outboard. It recently started giving me random trouble while out. I would be out for a while fishing, then once i decide to return after a few hours, it starts to play up. It starts fine, but when i put then throttle down full, it dies off, runs like it is starving and losses speed. If i back off the throttle it will usually be ok again until i try to go fast again. This has happened the past 4 times i have been out. As soon as i stop and idle, including with the engine reving at near full speed, it seems ok. But then when i go to take off, it dies off again. It is always on the return trip when it plays up. I have changed the spark plugs and made sure fuel is flowing through the lines. It does not stall, just losses power and sounds like it's starving.
Of course when i take it to the mechanic, it runs fine, but i can't afford to pay him to spend hours hoping to find a random problem. I can only do minor mechanical stuff myself.
Any ideas please?
Any ideas please?
