GoFastr
- Aug 26, 2012
- 73
Had two gouges on the hull repaired a couple years ago where the gelcoat was chipped off due to a couple dock dings. One was at the transom on the lip of the swim platform, and the other was on the forward starboard shoulder just above the rubrail on my 32 powerboat. The "reputable" local shop that did the work enlarged the areas from about the size of a quarter or half dollar to approximately 3x6" areas...The problem now is those two spots in what should be bright white gelcoat, are now noticeably yellowing.This is not organic yellowing from sitting in the water.
I've read everything from FSR, toilet bowl cleaner, On/Off etc. to wetsanding starting with 220 moving thru 400/600/1000 and finishing with 2000 grit sand paper. Other threads blames it on the oozing to the surface of the compounds like stylene? and whatever else is in it to bond.
Is there any merit to these fixes? I've never wetsanded gelcoat and it scares me a bit to scratch up the boat and not be able to get it back to a glossy finish and have to take it back to the repair to fix a self-inflicted wound.
So any new experiences or tips on new products on the market would be helpful. Any guidance on properly wetsanding a spot like this would definitely be helpful if I have to resort to doing that.
I looked up a product put out by claneashine.com that looked really promising on their website video, but they're located in Australia and the shipping costs was as much as the products.
BTW, the boat is still tucked away coccooned up or I would take and post pics.
Thanks in advance
Thanks in advance
