Battery Full
agallant80
Can anyone smarter than me give me a general idea of charge resting to 4/4 3/4 2/4 1/4 (Empty to full)
Moody Blue
Re: Battery Full
Is this what you are asking?
12.60 V 100%
12.35 V 75%
12.10 V 50%
11.95 V 25%
11.70 V 0%
as posted on Wikipedia.
bruceb58
Re: Battery Full
Make sure you take your voltage reading about 30 minutes after you take the charger off or stop your engine or you will be measuring a surface charge.
tazrig
Re: Battery Full
It would also depend on the type of battery you have. For example the above numbers are for a standard or deep cycle flooded battery. If you have an AGM battery the numbers would look like this:
Full state of charge = 12.84v or higher
3/4 state of charge = 12.5v
1/2 state of charge = 12.2v
1/4 state of charge = 11.9v
source: Odyssey AGM Marine Battery Manual
I'm not quite sure why the numbers are different, possibly because there are more lead plates packed into an AGM than a conventional flooded battery.
