Re: Dry joint exhaust
Yes, it can be done. May take some replumbing. Depends a lot on how yours is set up as to what all it will take, is your closed cooling system OEM? Are the manifolds cooled with antifreeze now? I assume you have an engine mounted raw water pump?
What is the serial number of your engine, engine year and boat year aren't always the same.
