SilverSS07
- Jun 13, 2012
- 266
Almost done getting her back together! It's a 1982 Evinrude 140. I put the intake/carbs back on today and noticed that when I operated them manually that the lever that changes the timing advances when opening the throttle but doesn't go back when you let off of it. I took apart the mechanism and cleaned all the old grease and dirt out then greased it and put it back together. It moves easier now but the timing linkage still stays in place.
Here's where the lever stays after opening and closing the throttle.
I tried spraying some lube on it but that didn't help either. Should there be a return spring on the mechanism under the flywheel? I looked in the service manual but couldn't find anything about it. Thanks for any help.
