I recently bought a 1978 johnson, the previous said had water impeller replaced last yr. the motor runs fine but it takes at least a min. or longer b4 any water comes out of the pisser, once it starts it comes out real hot at first then it cools off after a min. or so. the water pump seems to pump good once it starts pumping. is this a bad thermostat or water pump? thanks.
