I have a problem with my 1998 Sea Rayder.
The boat used to go 50mph and now struggles to get to 30. I took it to a mechanic who adjusted the timing and installed new plugs but it did not help. I checked the spark while cranking and I get intermittent spark at every cylinder. None of the plugs spark at every revolution, some only spark occasionally. Always in an irregular pattern. I put in one new switchbox last summer and it was never the same after that.
Should I see a good spark while cranking? Is this a bad Trigger? Stator? There are so many expensive parts on this motor I don't want to replace them all if I don't have to.
