Re: My &0s Tilt Trim
Why do you want to change the oil type? True, some oils do destroy the seals in a shorter period than others but they all can last 20 years.
NOW--If the trim is not working and you need to repair it, sure, change the oil while you are at it, otherwise--leave it alone.
To completely change the oil, you need to remove all four lines from the pump and cycle the engine up and down to its full travel a couple of times to purge the cylinders. Then you need to suck the reservoir dry through the fill hole--not easy, or run the pump and blow the oil out of the reservoir, or drop the pump body and drain the reservoir.
