Oil Leak after service
buckersz
I put my Mercruiser 4.3 EFI in for a service to have the thermostat replaced, an overheating problem looked at and a starter motor replaced along with the usual service. When I got the boat back, after running for a couple of hours I had a pint of oil in the bilge. Back to workshop where they told me hoses to/from oil filter were weeping so they were replaced for more $$$. After a couple of hours running I had about 1-2 pints of oil in the bilge again. Workshop claim that nothing they have done could have caused the oil leak. Question is, is it just coincidence that oil leak started after service or could they have done something and also any suggestions where oil is coming from. There is no leak obvious so must be low down on the engine.
tpenfield
Re: Oil Leak after service
Welcome to iBoats . . .
See you thought that you were bringing your boat into get fixed, didn't you?
Has the shop thrown in the towel and left you on your own? Could be coincidence, but you never know.
One thing for sure is that their diagnostic capabilities are poor at best. If they said it was an oil line 'weeping' and they replaced it, that should have fixed it.
Get your mechanics mirror and flash light out, time to go looking on the dark side of the engine.
BTW - is there a different boat shop in your area?
