I_5320
- Jan 3, 2011
- 59
I think I maybe over-thinking my trailer. Maybe not.
Never gave tires much thought, Always replaced every 5 years and kept them on boards out of the grass. Also carried 2 spares and never used them. My old boat I'm pretty sure had Carlisle 480-12' B's. Rig was lite, about 800 Lbs.
New/old boat & trailer I estimate will be about 1,100 lbs with no more than 1,300 tops finished out. ( I will weight when finished) Current tires are Carlisle USA Trail 480-12 B also. So they're rated for 1,560 (780 ea).My issue is in researching spares, I read that these have a habit of blowing out. Wondering if I just got lucky with the lite rig before.
Also I read that Class C needs 90lbs tire pressure to deal with it's 980 per tire capacity. I had a hard time with 60 lbs but 90? Rough ride yes?
Is a Radial overkill for 1,300 lb setup? I only see one that's close on a Kendal S trail that's 1/2" bigger and 3/4 wider.
I really don't have much, if any, room on the width with my fenders. Anyone know of a Radial that's a direct replacement for a 480-12?
Recommendations. (Brands also)
1. Stick with 480 bias B since I'm perhaps 14% below capacity(And I read B's run cooler than c's)
2. Upgrade to C's
3. Go to Radials (find a match or deal with fenders)
FYI, I do take 7-10 hr trips and like to go 70ish when I can.
2. Upgrade to C's
