Private Nemo
- Nov 7, 2011
- 60
Since spring is around the corner , I am starting to think of the things I need to do.
My AC has a problem that I have not been able to solve. The water cooling pump loses pressure and does not circulate water, of course the AC shuts down. I thought it was the pump so I bought a brand new very expensive pump. Same problem. I check the lines all clear. If I take the intake line off the pump when it stops circulating , plenty of water comes thru the line, I could sink the boat pretty quick. Most time the pump will start to circulate again, for awhile.
any help is appreciated
Drew
Drew
