I just bought a boat with a 1999 115 ELPTO on it. I was not able to run the boat on the lake, etc. before purchase but did hook up the ear muffs and run the engine. It ran fine. Now that I've been able to get it out on the water, though, it won't rev above 2500 RPM when in gear. If I take it out of gear I can get it to rev to 5000-5500 but it smokes a lot and runs rought. If I put it back in gear it will not rev past 2500, which won't even get the boat on a plane.
This is a 2+2 engine I believe and I took the cowling off and had my daughter push the throttle handle all the way forward. It looks like there are two throttle cables coming to the motor but it looks like only one actuates. I can grab hold of the other one and pull it forward but I wasn't where I could run the engine (it was on the trailer with no water source for the ear muffs).
Is this the way these engines work and if the other throttle cable engages the other two carbs would it behave as I described, i.e. won't rev past 2500 under load and when in neutral smokes bad and runs rough.
Any guidance, ideas, suggestions would be welcome. I had the compression checked prior to purchase and all 4 cylinders checked out fine.
Thanks.
Thanks.
