1998 Johnson Tilt Issue
Shane0524
I have a 1998 70hp Johnson with power tilt. The engine moves up and down fine but when it is moving it will make a loud cracking/popping sound. It appears to be coming from what I think is the hydrualic motor. Any ideas as to the issue. Here is a link to a video of the engine.
1998 Johnson outboard tilt problem - YouTube
boobie
Re: 1998 Johnson Tilt Issue
Have you greased the two fittings on front of the tilt tube ??
Shane0524
Yes that is fine I can feel a pop coming from the motor would air in the system cause??
