32bit.flannel
- Mar 14, 2011
- 43
Hey guys,
I'm running an 87 Starcraft FM160 with an 87 Suzuki DT65. I really like the power of this motor, it gets the boat up on plane right away and pushes it the same speed no matter the body count (I've run with 4 onboard and one in tow and it just goes). However, it seems to top out max speed at 3/4 throttle. When I push it to 100% throttle you can hear the engine rev up a bit more yet I gain absolutely no speed. (Note: This is NOT the famous rev-limiter problem, the engine is revving all the way). The prop it came with (when I got it) is a Michigan 032042, 13x11 1/8". The boat isn't heavy, and this happens even if there are only two of us with only 6gal on the boat on a flat day. My best guess is that I am just under propped? I do not have a tach so I cannot say for sure what RPMs I am running, I just know by ear that the engine easily rev higher without increasing speed. Thoughts? If you had this motor on this boat what prop would you automatically select? Mostly used for fishing inland or near shore (got a kicker for trolling) but we like to get out on Lake Erie to play in the summer too.
Thanks!
Nick
Thanks!
Nick
