Hey there.
Decided to try my new bought Evinrude 3hp today, but i ran into a lot af problems pretty fast..
Firstly, the pull cord was really hard to pull. It seemed like it worked as it was supposed to around 1 of 5 times. The other 4 times, it stuck halfway, or needed a lot of force to go anywhere. Suddenly while pulling, the cord got all loose, and I could pull it all the way out without it going back in.
I popped the case open, and saw that the small gear had moved to the wrong side of the big one, as I have tried to show on this picture:
After loosening the bolt I've marked in red, I managed to get it back in the right position, but now it seems like something else got turned, which I cant get back. When pulling the cord now, it is getting caught between two turning wheels, causing it not to be pulled back inside engine. I hope the following two pictures illustrate what I mean:
Also, when messing around inside the motor, half of the times I couldnt move the speed handle afterwards. Maybe the problems are connected somehow?
Can anyone help me get it back in working order? It would be really nice to try and get that thing started and running
