FlatCat_80
- Feb 28, 2013
- 6
Here's the deal. I just bought a 1989 Blue Fin Runabout (Bass/Ski). The guy I bought it from started it up and showed me it ran. I bought a new battery & took it out on the lake. No problems it ran great for about 10 minutes before dying!!! =( Okay so I start hearing an arching sound from the battery/gas compartment & open it to find the Negative terminal is completly melted off and I can see the acid. "Great!" Now I grab the wire & move it & disconnect the Positive. So I get a new battery start checking wire & decide to connect the battery. Then we run into another problem! We could not get it to start... Well needless to say it started getting dark & I was too tired & madto work on it so we started clean up. Then it happend!!! While my brother-in-law was grabbing tools & I was lifting the motor to put the brace on he hit the power wire & seen a spark on the inside by the motor. We looked & noticed the Postive power wires closest to the engine has metled & were making contact with the ground via the motor. So here is my questions though they may be very stupid.
Would that keep the engine from starting?
What other problems should I look for after I replace the wiring?
*Note: The only things I have done so far is install a new impeller & purchase a new battery.
