beachbum8200
- Sep 4, 2012
- 9
Hey guys my tilt motor will stick a lot and I will bump the motor and it will work is my motor going out and if so how hard is it to fix thanks
I will hit the switch on the side of the motor to tilt it up and I here a click and I will take my hammer anr tap the motor and it will work for a lil bit but I always have to tap it againmarine motors have to be spark proof so fuel vapour can not ignite.ptt/starters are sealed and any condensation inside will cause the damage.sqiurt of light oil will fix trouble most of the times.carefull,there are springs inside.
Very Very likely its the brushes. Check this thread for a link to a manual you can read over and see if you want to tackle it. If it's not enough information, PM me for more info.
http://forums.iboats.com/mercury-mariner-outboards/pt-t-question-592445.html
<Edit> I just looked over that link. There is another one around recent PT&T related threads with a more comprehensive section on servicing the pumps. I actually saved the pages myself for future reference.
