phillnjack2
Ensign
- Apr 30, 2011
- 918
My engine is
Evinrude 3 cylinder 60hp year 1995
model is BE60TLEOC
Ok while doing normal service stuff ive changed the thermostat and impellor plugs greased everything
checked jusy about everything possible.
The engine starts up just like it should and seems to be running fairly good and will rev instantly.
Today i started the engine and ran it in a 80 gallon water butt for around 2 hours.
The outside temp today where i live is around 42 degrees F or around 6 C.
The engine seemed to be warm but NOT realy warm enough. !!!!!!!
I have fitted a temp guage and it only got upto 60 degress C, thats 140F.
The sender is screwed into the cylinder head threaded hole at top right hand side of cylinder head.
the 2 exhaust holes at top of mid section only had the very slightest of dribbles comming but not all the time.
When i revved the engine i could get a bit more out of them but then after a couple of seconds the temp
dropped to around 53C (127 F ).
I can hold my hand on the cylinder head although its on the point of being a bit hot after 20 seconds ha ha
the exhaust at the side of block is also just very warm, not burning hot in any way.
The tell tale is very strong and warm water comes out of this, (it was perfect for hand washing with some soap).
Now with the engine idling at 1,000 rpm should i be getting lots of water from the 2 exhaust holes ?
I was getting too much water from before as the thermostat was fully open all the time and thats
why i got a new one.
The new thermostat has 143 written on the side and is a genuine BRP product.
Why would the engine not get warmer ? what am i not doing right ?
there is plenty of 2 stroke oil in the fuel as ive switched to premix a while back due to faulty vro pump.
The engine starts perfect and the quickstart is working fine and switches to normal mode after about 1 minute.
I have not found any build up of limescale or salt build up anywhere, and like i say the tell tale is very strong.
I took the cover off the thermostat housing and took the thermostat out and turned the engine over, the water
absolutly pours out like a firehose so ive got very good water pressure from the pump.
what should the engine temp be at idle ?
i thought it should show the thermostat opening and water exiting from the exhaust housing holes.
please help as im going round in circles and getting nowhere very fast ha ha
phill............
model is BE60TLEOC
phill............
