Hi, I need some urgent help please
1989 100hp 2 stroke mariner, oil injected, 4 cylinder. Great engine. has run well although didnt idle well, but once it got going was a good runner.
a couple weeks ago started losing power and just cutting out. Would restart, then would lose power again and cut out. ended up it wouldnt start at all.
I figured was a fuel block or something. I noticed the tote tank hose was loose at the tank end. decided to replace the hose. also replaced the fuel filter which is tucked under the throttle arms.
Fired it up again and was delighted to hear it purr sweetly during idle. first time it ran that well! took it out and it ran really well for 5 mins, but after I opened it up for a couple minutes, I had trouble slowing down. once I put it in neutral, the revs ran away to a very high level and I turned the engine off before something got damaged.
Things I have tried since then:
- checked fuel hoses, clamps and pipes for leaks, nothing looks wrong
- changed the fuel filter back to the original one
- changed the fuel hose back to the original one
- checked the throttle arms and mechanics for any sticking, nothing looks wrong
Nothing I do improves the runaway revs. its starts really easily (much easier than before any of this started) but quickly takes off to high revs and I have to turn it off real quick.
any thoughts or ideas? I dont really want to spend $$hundreds at the service centre if it might be something simple.
I just dont understand what has changed by me replacing the fuel filter and fuel hose...
thanks
simonp
thanks
simonp
