I have a 1996 150 Johnson and the cylinder heads have never been off. I am told that changing the Gaskets (O-rings) is over due. The motor runs really good but compression is around 90 psi.
I am planning on honning the heads, but regardingthe o-rings...is a gasket sealer used, and are there any inherent difficulties in this project? Same goes for the t-stat seals. Thankyou. Saltidog
