bogginyota
- Feb 26, 2013
- 59
"It's also coming from the pisser and the prop.
iT DIDNT LOOK LIKE IT WAS SHOOTING WATER OUT LIKE IT SHOULD TO ME , HARD TO SEE IN THE PIC THOUGH ..iT WILL THROW A STREAM OUT IF WATERPUMP IS WORKING WELL .. iD DEF.. CHANGE IT , EVERY BOAT IVE BOUGHT WICH IS TWO NOW HAD TO DO IT NORMALLY PEOPLE LET EM SIT THEY STIFFEN UP AND DONT WORK RIGHT !!!
All the water "leaking out of the lower and mid section is normal.
As long as the water is making it up to the motor, and coming out the telltale, and also finding its way back out the prop, you should be ok.
The idle relief holes on the back of the mid section, only spritz or dribble a little water. The older 85 and 125 hp would spray water out there, but not so much on the newer 120.
But yes, change the impeller if you are not certain it was done in the last year.
Also, check/replace your thermostat.
Thanks for helping me find some peace of mind with all the water coming from the lower unit, I only expected water to come from the prop, pisser, and the holes on the mid.
What would happen if i didn't run a thermostat?
Should my motor have an alarm/beep go off when i turn the key to the on position?
