Re: Outdrive identification needed
WOT isn't the thing that kills the drives, it's the slam it down full throttle starts that takes things apart.
You know how you plan to run it, I don't so it's not my place to recommend one drive over the other, Merc only used alpha drives on the big blocks for two years, then they came out with the Bravo drive.
There are people that destroy the alphas behind the big blocks and those that don't because they take it easy on the drive.
You get to make the choice, you know you, I don't.
Stick around, there will be people coming along that will tell you what to choose.
