Re: Guess my weight
What tow vehicle (make, model, year, equipment) and what part of the country are you in? Trailer is about 500#, motor about 280#, boat about 1800#, 20 gallons of fuel about 120#, coolers, batteries, PFDs, and other stuf add about 150#. Looks like about 2650#. You are within the limit of 3500# but read the qualifications for the tow vehicle. Whatever you put INTO the vehicle may deduct from the maximum towable load. This all means that you may be at the top of the tow rating which does not make for a good combination. Do your research before pulling the trigger on the tow vehicle but I'm guessing you already have your mind made up. If you routinely make trips in the mountains or hilly terrain, that calls for more power or better gearing or both.
