3 times a charm? I dropped L/U replaced impeller & it pumps water but only if I rev her up about 1/2 throttle. I dropped L/U a second time to make sure tubes were in place & they were. Removed t-stat same thing, removed pressure switch/ball same thing. I did not replace the aluminum pump housing or plate as they are pricy and mine looked fine. So I plan on dropping L/U again for a look, I am not that familiar with this model, but the manual I have (johnson 10th edition) has a jonny version & explains about water being re-directed back to the pump etc. So any ideas -help much appreciated. Pls feel free to be very direct, you are dealing with a simpleton
