Re: 2000 Ford Focus cruise control
I found this on a Focus forum. Mine came back with 4 flashes. (his paranthetical mentions wheel speed sensors, but that's NOT what controls the cruise system.) So I have to do a little more diagnosis under the hood.
Maybe you can try it out on yours and see what it says:
"If it's a manual, don't depress the clutch. If it's an automatic leave it in park. First, turn the ignition to the accessory/run position but don't start it. Press and hold the CC off switch and then repeatedly turn the ignition from run to off and back to run again, you should do this 3 or 4 times. End this sequence with the ignition in the run position and then let go of the off switch, and you should see your CC light blink once, which means it's ready to run the self diagnostic. If it flashes 5 times at this point then it's a faulty speed control module, which is that servo I mentioned above. Quickly after the light blinks (like a second after), you then need to hit the other cruise control buttons in this order, and you will need to hit them fairly quickly for the test to proceed:
1. On
2. Resume
3. Coast
4. Set/accel
The CC light should blink once after each button you hit. Kind of take your time hitting the buttons and it's easier to keep track of the flashes, which is important at the end because you need to count the number of flashes that come after you hit "set". There won't be an immediate flash after you hit "set", there will be a slight delay, and then will come another short series of flashes. This next part is all verbatim (except for the parenthesis) from the Ford guide I'm translating here.
0 Flashes (no flash after last button is pushed): suspect circuitry or speed control steering wheel switches.
1 Flash: Static test passed (cruise control should work)
2 Flashes: BPP (brake pedal position) switch is damaged, circuit is damaged, or the brake or clutch pedal was applied during test.
3 Flashes: Brake deactivation switch is open or circuit is damaged.
4 Flashes: Indicates the speed signal circuit is open or damaged (wheel speed sensors, ETC)
5 Flashes: Suspect circuitry or module."
Thanks for the tip. I've done this before, and get 0 flashes.
You can hear the module buzzing when it's attempting to run the self check.
IMO it's still a module issue.
Buttons on wheel turn cruise On/Off, Set turns light on when attempting to set cruise, other buttons flash cruise light during test. They should be good.
Brake pedal still cancels light on dash. Should be good.
Vehicle has no ABS, cruise works off the VSS signal. Speedo still working, and VSS PID on scan tool indicates proper speed, so the VSS is working fine.
Cable from module to TB is intact.
What doesn't happen is the gas pedal doesn't drop when performing the test. Part of the test is actually running the servo to check cable/servo integrity.
I assume this module is networked into the PCM, or maybe the instrument cluster, since it needs to read data from the VSS. Would have been smart if Ford had also integrated the TPS signal into the test, and monitor TPS voltage to see if it changes when the servo is actuated. Doesn't seem to be the case...
If I feel ambitious sometime, I may pull it out of the car, and open it up to see if the problem can be visualized. Other than that, I'm gunna live with it till I can get to a boneyard, or I find a reasonably priced module.
