Tanganyika
- Feb 17, 2013
- 1
Hi, am new here coz getting crazy with no injection signal from MEFI blackbox. Have searched in this forum and other websites, but am stuck. Living in Burundi / Africa on Lake Tanganyika, no mercruiser dealer with diagnosis system around.
After replacing a piston, rings and a complete seal kit, the engine starts when pouring fuel into the Carb injection, engine is running nicely. I did not touch whatsoever electrics/electronics, except this harness connector which is moulded into silicone, but checked all cables for contact, all fine!
Checked all the safety signals which could stopp the injection from giving a on/off signal:
Neutral, lanyard switch, oil pressure switch, temperature switch, Throttle position, knock sensor, fuel pump is running for a sec or 2 when cranking. Checked the harness for any damage, fusibles ok, relays working, stern drive oil level ok.
found a great website where all voltages are described in details: http://www.bakesonline.com/images/MediaLibrary/Indmar_MEFI4manual.pdf
checked all in and out voltages from the different sensors on the MEFI Blackbox, everything ok !
Despite those checks, the injection is not sending fuel signal. When I give direct 12V to the green and blue wire on the injectors it is injecting fuel.
Anyone who could help ?
Thanks
Thanks
