phillnjack2
Ensign
- Apr 30, 2011
- 918
Hi guys.
I have a 1995 evinrude 60hp the 56cu in model no BE60TLEOCive got the later tell tale pipe fitting on the top of exhaust housing and like the idea of fitting a
water pressure guage along with water temp guage.
Ive got the temp guage and fitted that to original threaded hole in top of cylinder head on
the right hand side.
Now for water pressure Instead of using the T fitting in the tell tale pipe would it be ok to use the
fitting on the exhaust cover that used to be a tell tale outlet on older model engines. ?
The reason i ask this is because using a T- fitting in the tell tale is not going to be anywhere near
accurate as water will still be going out the tell tale and only half the pressure to the guage if im lucky.
Is there any reason not to use the old threaded housing piece on the side of exhaust for water pressure guage. ?
This would still allow exactly the same water out of the tell tale, just that i will have a reading of pressure
before it escapes from the exhaust housing.
pic below to show old exhaust threaded hole for tell tale on earlier models.
phill.....
phill.....
