Re: Transom cut??
Pics...we need pics...
First of all, does the cut down transom affect the position of the motor in a negative way? Cavitation plate too high or low?
Is this simply a cosmetic repair? Or, is it structural?
Then...
IF :and only, IF...
The transom is in excellent condition, meaning no rot way down low, or any where for that matter...and it is solid through and through...you have two more options besides replacing the entire transom to gain just two lost inches...
You can add a manual jack plate...OR, if the motor has multiple mounting holes, you could make your height adjustment that way, if there is enough left...another option would be to re-drill the mounting holes in the transom to change the elevation of the motor and seal up the old holes with some PB/4200/5200...
We'll be here waiting for pics...
