WillemWallace
- Mar 2, 2011
- 34
Hi Forum,
I have a "new to me" Johnson 6 HP "Sailmaster", model J6SLCOB, a 1985 20" shaft. Doing a waterpump service, as no history of maintenence came with motor. I have never done this before so I have a couple questions. I have removed the lower unit, and the 5" extension came off with it, as I assume it is supposed to. Now how is the extension secured to the gear case? The only bolts I can see are 2 small ones on the cavitation plate, just above the prop., right near the zinc anode. These bolts do not look like they are holding it on, but I see nothing else. Second question: The copper water tube that comes up out of the top of the impellar housing of water pump remained in the upper part of the motor, when I seperated the lower unit. From what I have read, it is supposed to remain attached to the water pump, when I dropped the lower unit. How do I deal with that? Any info is greatly appreciated!
