Hello! I'm hoping you guys can give me some direction here. On my boat I have a 72 evinrude 50 HP lark. This is on our first boat and honestly I didn't know a lot about them when we bought it. Anyway, it ran pretty well for a while - guy we got it from said the carbs had been cleaned within the last year, had good compression, and new water pump put in recently but it wouldn't go in reverse (don't know if that has to do with current issue but figured good to know).
It ran pretty well several times out and then the last time it ran really the best it has ever, just great - until we stopped to fish for a while. Went to restart it and it kept trying to turn over and over, even without the key in it, and I had to pull the battery to get it to quit. Got myself the original manual and started trying things. At the time it happened I thought maybe the ignition was broke and replaced that, didn't help. Since I've replaced the solenoid, starter, rectifier, put in new spark plugs, and new ignition coils. It turns over but its not firing. I should mention it doesn't have a neutral safety switch, it looks like it previously was rewired and they apparently bypassed it. The only thing I can think of to try replacing now is the power pack - but wanted to check with you all to see if you had any ideas about a next step, all these new parts are killing me lol. Thanks so much for your thoughts!!
Jason
Jason
