Flipperboat
- Feb 21, 2013
- 13
I know you guys have addressed the issue with this ignition system before and I read most of the post. I was looking for a step by step way to check each component of the ignition system. Is there such a thing? What kind of tester checks the condenser these days? I do not understand how to get from point a to point e? Please go easy on me, this is my first merc and after this I might go back to the C horse. Just my luck that I picked this one right out of the gate.
First thing I found all of the wires disintegrated so I thought I would just replace them. I took the top orange cover off the ignition plate and no problem just unscrew the wires and replace them. Penk, screw broke right off flush with the plastic. Ordered another one and think I got the last one in the country (OEM) And what ever happened to an assembly being all of the components included? I just got one piece for a mere $150. A bit pricy? Then the wires going to the little white insulator blocks were also disintegrated so I ordered those as well but they sent both in brown. I didn't get a white wire but what do I care as long as it will work and I know which wire it is. Found the last of those as well. So before I put it all back together wanted to check the coils and condenser. I had a digital meter but somehow the values were off. It appeared that the high speed coil is bad but I want to make sure I am reading it right. I had to give back the borrowed digital meter and now only have an analog meter. Can I still check coils with my analog meter? Any help would be appreciated. I really don't want to throw more money at it but I have come so far.
