chrisasealtite
- Feb 22, 2013
- 1
I bought a pair of jetskis 3 days ago. Both were running and starting fine. Engines newly rebuilt. After running them out on the water, one ski will not start. Starter does not turn over when key switch is on and starter switch is depressed. Starter does roll over when jumped at the starter relay. I installed a New starter relay anyway. Grounds look good inside the DCI and on the battery and starter. I tested the magnetic key-switch and the starter/kill switch and they are good.
The instrument gauge cluster was blinking on and off on the last ride. On the opposite jetski the red warning light turns on when the magnetic key switch is turned on. However, the red light does not turn on on the jetski that will not start, but not sure if the red light works.
Any guesses will be appreciated.
