fireftr1990
- Jan 19, 2013
- 5
1995 Chaparral 2330 with 5.7L EFI
Boat was seldom used by previous owner who had for 3 years. Ran 3 times went to go do maintenance since other owner said he never done any. Boat ran great the 3 times I took it out for about 1 hour on 2 and 3 outing each time no hard running mostly put putting up and down river. Upon running motor to warm up for first oil change hose came off flush muff and motor got to about 220 deg. shut down re-hooked hose started and temp went back to normal doing oil change found milky
but no excessive fluid
changed oil ran for a few seconds to fill oil filter to check level. talked to some friends recommended to do another oil change to get all milky oil out. Now the fun part went to go start 2 days later to warm oil for removal and engine hydro locked pulled plugs water in #5 and #6 only. new riser and exhaust manifold ordered arrive 2/25/13. Put pressure on all cylinders and they were tight Compression was good on all except 1 and 2 were low?? again motor ran great before hydro lock happened when idling in driveway with flush muffs on never ran hot. any other suggestions would be appreciated.
