i was at my buddies house working on the trophy & he was working on his 14ft keywest.<br />he had a friend come over who claimed to be a fiberglass repair tech & proceeded to help him fix some grounding spots, breaks in gel coat- standard stuff.<br />before i knew it they had taken a wire wheel <on drill> to the spots. with no clean up other than sweeping with a rag- they started coating with poly resin than glass cloth+ more resin. i was shocked!!<br />- <br />this was placed on the bottom, sides & transom.<br />the guy told him to put it in the water tomorrow and if it held it would be ok????<br />am i mistaken in assuming that the unprotected, poorly prepped patch work wont hold up underwater?<br />-<br />my buddy wants me to fix it with out removing the work.<br />what can i put over it to seal it and cover the resin?<br />gulvit with coloring, interlux vc-tar epoxy coat or VC performance epoxy bottom finish??<br />-<br />i only want to do this one time to atleast cover the problem, but dont know if the epoxy base coat will adhere to the poly resin patch repair.
