bigballerg
- Dec 26, 2012
- 100
Did a fuel pump conversion that worked successfully took for spin etc.... Worked at idle for the 1st time ever and also cruised WOT for 20 min around lake back and forth WOT to idle etc... worked like a CHAMP!
THEN.... Boat sat for about 2 weeks when I went to start it would not turnover. Battery full charged. Cranks, cranks, cranks but will not go, UNLESS I pull a spark plug and spit some gas in there, replace spark plug then try and turns over... runs great.. after its on for a few I kill it. If I try to start up again, it works perfectly. If I wait a couple days, i'm back to cranking and removing spark plug etc.... NOW, I did take for a spin and idle worked great BUT at WOT it worked great for 30 seconds then slowly started to fade to eventually the motor seemed to be PULSATING (Wanting to go but wanting to die and getting me sea sick in the process) then eventually dying.... It would start right up after this incident at WOT. I repeated adjusting the high speed needle, but at WOT eventually died... Not flooding because I could turn over instantly... more like starving for fuel or SUCTION??
