Hi all,
Have a 76 - 85hp merc with PTT. Pump is the A series, 4 hose , 2 cyl. Noticed when I applied additional throttle in reverse the engine would jump a bit, Does this everytime. Didn?t before.
Checked out all mounting hardware, and nothing is loose . I?m quite sure the problem is my
pump. My merc manual states a defective check valve, will cause trim cylinders to fail to hold
reverse thrust. (By the way, oil level is OK.)
I am guessing this check valve is in the control valve assy. As I cannot find an exploded view
anywhere. Manual also states control valve is not repairable and must be replaced as an assy.
I was going to pull the control valve, Inspect and clean shuttle plate and replace the 4 O-rings.
Can I get into that control valve to see if there is a problem with a check valve. I?m sure
someone out there has opened one of these up. Appreciate any guidance.
Thanks in advance
hereto
Thanks in advance
hereto
