A week or so ago I discovered a small puddle of gear oil on the ground under my MC-1, appearing from around the prop exhaust area. In the twenty engine hours prior it has had the pump and associated seals replaced, as well as the lower shift shaft seal.
Local mechanic suspected a leak from the upper box seal where the shaft enters the leg exhaust cavity, so I got him to remove the out drive and investigate. No sign of a leak at the top box seal, nor down around the prop shaft seal.
The mechanic pressure tested the leg to 17psi over night with no pressure drop or leak.
There is evidence of water contamination in the oil.
Mechanic is thinking it may be a leak past the water pump seal; when the engine is running the pump is forcing water into the leg, so he changed the oil and suggested I go use the boat for an hour and recheck, and do a vacuum check of the leg.
This sounds feasible to me, but I can't help but wonder why there would be an oil leak while its sitting on the hard stand, but then hold pressure under test? Heating / expansion of the case by the sun perhaps?
There are signs of corrosion within the drive where water would normally travel, so it may be possible that the carrier where the pump seals are pressed in have developed some pitting, causing blow by? Can these seals be installed with some sort of sealant to alleviate this?
Any other suggestions, before I pull the lower box off and investigate pump seals?
Cheers
Cheers
