I would like to mount a Honda EU20001 companion generator (30 amps output) in the trunk of my Monterey 250CR boat. The thought is to be able to run the generator in the space over night to provide heat in the cuddy. The trunk should isolate some of the sound from it running. The generator should run about 8 hours on a tank of gas. I can refill it the next morning from the boats gas tank if needed. It will also charge my batteries for the next day.
The thought is that the generator is about $1,000 and to add a diesel fuel heater will cost double that.
Thoughts?
I'm going to cut a hole for exhaust to exit.
Thoughts?
