Mercruiser 5.7 alpha thunderbolt IV - nightmare - no start
Patriciah22a
First and foremost thanks to all of the members on this forum that have provided invaluable information for my prior research, I am convinced I've leeched dozens of hours of reading and for the most part it was extremely helpful. I hope I can give back to the community in the long run.
Here's my synopsis. 1996 Maxum SCR2400 with mercruiser I/o 5.7 2bb carb. I am a mechanic and am prepared for the worst.
The boat was purchased last summer, it ran at this time, poorly, but ran nonetheless (starting became exceedingly difficult and required a substantial amount of throttling and excess rotations before it considered starting). Finally I was unable to start the boat but my persistence resulted in a seized starter solenoid. Due to the nature of my emergency a cardinal rule of boat mechanics had to be broken: I installed an automotive starter matching the Chevy 350 configuration. This got me back to my previous stage of "barely starting" (the automotive starter was missing one of the terminals - I suspect this lead was for the coil if memory serves me, I bypassed this with a switched hardwire to a constant 12v source). The boat at this point ran hot. After a proper overnight cool down and replacing the overflowed coolant i attempted to start it again. (No coolant in oil, no evidence of blown headgasket). Wouldn't start as expected. Decided to inspect the cap and rotor - they looked extremely worn so I replaced them. This didn't result in a start (just a semi-healthy crank). I had to abandon ship (literally) and come back to home (2 hours away from the beach where I keep the boat). I had a local boat mechanic swing by to check on the boat. After a bit of diag he noticed my wire order was off on the cap (must have happened when I installed the new cap/button). He said it fired up instantly with no throttle assist and idled perfect but it would run hot shortly after. It never left the dock at this point. I returned to the boat to move it back to dry storage the following night. Sure enough the boat effortlessly fired all 8 with the bump of a key in a Lexus-like fashion; while trying to understand how this miracle occurred I watched the temp gauge climb. This confirmed two things - 1, I made a good call on the cap/rotor needing replacing, 2 that I was still dealing with an overheating issue. I decided to diagnose the cooling system on dry ground which I wasn't too familiar with - when attempting to inspect the lower unit pump it turns out to my surprise I didn't find a damaged impeller, rather it was missing altogether - yes, someone actually removed it and reassembled the housing ((the mismatched 4 housing bolts were an indicator of the past maintenance history of the boat)) so just a shiny shaft with no signs of a past impeller OR key way. I purchased all new components and proceeded with proper servicing protocols. I inspected the raw water pump also and found all impellers missing from damage, I also replaced this along with a new housing. Now with excitement I put the boat in the water - yet again a perfect start and smooth idle with no hi-temps. I thought I conquered the world and loaded my rods and bait with a huge grin on my face. The moment I engaged reverse the boat died. Of course this was the result of a shift cutout switch being slightly out of alignment. No problem, return to neutral and try to fire, NILL. Back to square one, the prolonged turning over yet this time it yielded no result. No start, just an endless crank. I towed the boat back to my shop in Raleigh and decided to proceed with a mild ignition overhaul. I tried starting it with muffs and eventually got it to fire but this involved starting fluid and was by no means the Lexus start i was previously spoiled by. Gameplan in effect: New plugs, new coil (Accel??), carb rebuilt (Rochester 2bb). Lake test had poor results - no start. I wasn't equipped to diagnose spark but at this point anything is possible and it may have been missing. Fuel was surely present. After further diagnosis with the company of a fellow boater we were yet again able to fire it up straneously on muffs, this confirmed we had spark and fuel. Minutes later I noticed oil (mixed with fuel) coming from the dipstick!!! My crank case had filled with a mixture of oil and fuel now. I attributed this to the hour long attempts to crank whilst not having spark. Project on hold. Decided to inspect the mechanical fuel pump for a ruptured diaphragm and of course replace the crank case content with fresh oil and a touch of Lucas. I spent another 10 hours tracking down wiring and finally ensuring the coil was getting the proper signal and sending a spark to the distributor. Confirmed perfect alignment of cutout switch and proper ohming results. I even temporarily bypassed for diag sake to get the boat fired up. I inspected the ignition sensor (under the rotor button and while it looked rough, it all appeared to be correct with both (maybe 3) resistors intact. This unit has two wires - white/red and white/green. I found a lose ground in the vicinity and added it to one of the cap screws in line with this sensor (alternate online part generic searches showed a consistent presence of a ground wire, this all appeared to be proper. I tested the modules that allow for testing (tapping white/green wire to ground repeatedly to check for spark at coil, confined blue arch). I then confirmed spark is present at distributor points. Fuel pump took awhile to prime after reassembly, but proved to function properly. So at this point I had fuel and spark, what more do you expect from a 350?! Random backfire in the carb and no start resulted in yet again second guessing my firing order. Intake is stamped clearly with the 1-8-4-3etc order and all cylinders are labeled. Since the cap had no markings, I did some brief googling and found most suggestions that cyl #1 would be in the 5 I clock position. I corrected this order (that my boat friend that had recently helped me work on the boat when the oil/gas/dipstick happened, he decided to revisit my firing order, I had to many beers at this point to remember why be changed it or if he even did) according to the diagrams found online assuming I has the right location of cylinder 1. This again resulted in backfire and no start. Hours of pointless diag later, I pulled the cap off and bumped the motor to tdc (I assume its what it was at when I lined up the block marking with the crank pulley groove). The rotor button pointed to cyl 1 being one over from what I had previously assumed. Excited and hopeful Moved the rotation over 1 and expected results. None whatsoever... Perhaps no backfire in the carb but no start. At this point I hang my hat up. Quick recap, I have fuel and spark (at least to dizzy points - I didn't have a 3/4 plug socket to pull the plugs and confirm spark, and to be honest I don't know that I checked for spark on the plug end of my wire... I was delirious at this point and the fuel fumes were grossly at fault). Next step would have been to check spark at plugs to eliminate the possibility of my wires magically and randomly failing and to see if the new plugs were fouled completely by the new persistent attempts to fire. Safety switch is jumped to eliminate from the equation. Tach wire removed from gauge to eliminate coil short to ground. Cutout switch functioning correctly. Main round engine harness checked (to the best of my ability) and proved not to be faulty. Prior to making this post I read a thread of someone with a random no start issue claiming the rotor button tab sheared off resulting in a random spinning, last I roved it it appeared intact and it didn't require force for reassembly. Ignition switch showed functioning leads in proper rotation (red/blue power and start 1 & 2 being purple and yellow/red ((this is all from memory so don't hold me to it))). I am questioning a possible engine ground??? No reason to believe this is at all possible as all connections appeared intact and all 12v connections checked out with proper multimeter readings using existing engine grounds.
I realize this has to be the most outrageous forum post ever and I hope I didn't violate any rules by posting this. If nobody reads this I totally understand and I also would be overwhelmed upon clicking this thread if I stumbled upon it. I also apologies for typos and various misuse of terminology (ie. cranking). I also may have possibly submitted this post earlier on prior to finishing which surely would throw someone off, I have written this on my phone while having the wife drive us home from the beach. Another quick note, the boat was freshwater kept until I took possession of it and put it in the ocean. It is kept in dry storage when not in use. I also want to point out this boat belongs to my clueless and helpless parents so all of the hours and money invested will never see a proper return. You may ask why I tackled this nightmare and I will tell you (with regrets) that I saw a challenge and thought I could defeat it; bad idea. I also have zero marine mechanical knowledge, my only prior marine experience was owning a 05 Air Nautique with 80 hours on it that required ZERO maintenance during my ownership. I am a self-proclaimed mechanic, rather a SUPER HARD CORE CAR GUY - I own a shop but no longer have any real hands on involvement, rather I diagnose problems and let others bust their knuckles, I do however take pride hands on when it comes to my supercharged z06, big turbo Audi S4, 4 rock crawler fully built jeeps, bike, etc - toys offer a level of reward unlike anything else. Keep in mind this failed boating diagnosis has been humbling for several reasons but primarily because my trusting wife has been supporting me in time and emotion along the way with no results. If you are still reading (you're crazy!), please offer suggestions. This post was only this long from the get-go to eliminate dozens of other posts where I'd have to clarify my process thus fad. I hope this will eventually not only lead to a result for me but also provide useful information for future readers.
Re: Mercruiser 5.7 alpha thunderbolt IV - nightmare - no start
Ayuh,.... Welcome Aboard,.... Have ya ever heard of a Paragraph,..??
Patriciah22a
Thanks for the greeting! Yes indeed I am familiar with the standard definition of a paragraph. However my particular post carries no reasonable structure to be worthy of formalities.
Your greeting instantly stood out in your response from previous posts I've read on this site prior to joining; look forward to your input
akorcovelos
check spark at tue plugs. Sounds like a bad ignition module to me. Its located under the rotor in the cap. Cheap and easy to replace. Mine gave intermitent spark until I touched it, then it crumbled. Installed the updated design and it fited right up.
Don S
If you don't have spark, (no, I didn't read it) then here is the troubleshooting chart for the TB4.
attachment.php
Patriciah22a
I am more than willing to replace this module, I did however follow the procedures mentioned in the post by Don S and confirmed spark at coil. By tapping the white/green wire against ground to simulate spark. The directions are a tad confusing since I don't know if my accomplished results for a spark suggest a functional ignition module or the opposite.
Don S, thanks for your honesty in your response, I wouldn't read it if I were you either...
Welcome aboard....!!!!
I read most of your post, but if it wasn't for good punctuation, would be impossible to follow. If you edit it and go back, and just add some spaces after so many lines it would make reading much much easier, and you WILL get more helpful responses.
Ayuh,... Point is, None of Us are gonna give you reasonable answers if yer question causes bleedin' eyes, when tryin' to read yer it,...
Free answers are expensive, when there's Pain involved in readin' yer question...
Good luck...
Don S
Then you need to replace the sensor inside the distributor, not the module. Your tapping the wire simulated the rotor turning and seeing and not seeing the openings in the rotor.
Patriciah22a
i think i may have had the answer all along... the ignition test chart posted above clearly indicates that I proved the ignition sensor was bad... the fact that I was able to get spark to coil (therefore distributor). the only question remains... could this component have been intermittent and/or affected by random variables??
Patriciah22a
Amazing! I posted my previous post before reading this one. Thanks for the immense help. Amazing how a fresh perspective changes everything. A minor detail like this being overlooked cost me a great deal of time, but the notion of hope is exciting
Don S
Check the distributor shaft bushings (in all directions). When they get worn out the rotor can hit the module and cause problems.
And yes, the insides of the module can become intermittent. I had problems with one that would only fail when the engine got warm, with the engine hatch closed. I replaced the sensor just to find out if that was it. It worked fine with the hatch opened and the engine cooled just a little.
Patriciah22a
Can't thank you enough! I just picked up a Selco manual for my application and after a brief reading things are making much more sense. I do intend to revisit some of the "altered wiring" that's in place now and attempt to return to oem configuration with the assistance of this newly acquired literature.
Since I am gettin spark to the distributor "spark plug wire leads", I assume that the reason I don't get the engine to fire is because that sensor isn't properly applying the order of the spark (to the actual module?)?
On a side note, this manual indicates that the coil replacement should be specific for the application... Any reason why my standard off the shelf (Advance Auto Parts) Accel coil shouldn't work?
RogersJetboat454
:eek:
Have you found anybody that will publish your novel? :D
Two points I will make...
Point one
Thoes gas fumes that sent you into outerspace... They don't play nice with your automotive starter when the engine cover is closed. If you still have your marine starter, send it out for a re-build. If you don't, pony up for one, it could save your life, and the lives of others.
Point two...
There is no set location for cylinder 1 on an older round cap SBC/BBC Chevy distributor. There's an ideal position, but you can theoretically stab the distributor in any position, and call any distributor cap tower #1. If I were you, I would re-check the firing order. I'm sure as a wrench on cars, you know that TDC on the damper happens twice for cylinder 1 (end of compression, end of exhaust). Pull number 1 spark plug, stick your finger loosely in the plug hole, and have your buddy bump the engine over. When you feel air pushing past your finger, line up the damper to TDC. OR... if you want to be 100% sure, pull the valve cover, and watch cylinder 1 rocker arms move. When cylinder 1 intake opens, then closes, line up your mark on the balancer. The position of the distributor rotor at that point will be #1.
ktbarrentine
If you mean Seloc manual, then I recommend you get another (i.e, the "correct") manual from this forum.... just sayin'.
Patriciah22a
Rogers - publishing agreement in the works! On a serious note, I still have the original starter I intend to rebuild myself before my next attempt to fire the boat; this will not only enhance the safety on board but also allow my wiring to return to stock, eliminating the switched 12v to coil and returning the link between the starter and alternator. Point 2 - it appears I was setting my firing order based on the exhaust stroke! I can confirm that the distributor hasn't ever been removed and its still lined up with crank markings. I was 180 off apparently.
So, it sounds like I am dealing with all kind of exciting TO DO's on my next visit. 1. Ignition sensor 2. Firing order 3. Starter swap...
Ktbarrentine - what's this manual you speak of??
Patriciah22a
Since I have the lending ear of so so many generous and knowledgeable folks, may as well ask - where am I most likely to find the shrapnel from my old water impellers along the coolant system? Clearly I understand the bottleneck theory, yet I'm convinced experience and exposure holds a higher value. In hopes this boat will run, is like to prepare for such temp issues and order all replacement parts/gaskets. I also feel like my oil will be contaminated with fuel after my attempts to start the boat were relentless yet again.
Don S
Real OEM service manual downloads.
Engine
Drive
Ayuh,.... If you've got P/Steerin', it'll be hung up in the P/S Cooler, mounted in-line with the in-comin' waterline, from the drive, to the T-stat housin'...
Smell yer oil,... If it don't smell like gas, 'n the level hasn't risen, it oughta be just fine...
When's it's next scheduled service,..??
Hit yer enter key on occasion,... It's Easy, 'n makes readin' yer posts possible for Us ole farts,... ;)
