Surfnsnowboard3
- Apr 28, 2011
- 39
Hey guys,
I have a 17' Belmont ski boat. I currently have a Sony CDXM60UI head unit with two Polk EX602a 6.5 speakers. I just bought two Infinity 612m 6.5 speakers waiting to be installed.
Here's my questions. I want my boat to be bumping!
1. Are my old/outdated Polk speakers ok you think? They still work fine.
2. Should I add two more Infinity speakers to make 6 speakers in a 17' boat (assuming I keep the two Polk)?
3. Is the Pioneer TS-W259S4 Champion Series 10" sub good for this setup?
4. Should I get the MB Quart NAU660 6 channel amp or JBL MA6004 4 channel amp? (Does that change if I have four or six speakers)?
5. Anything else you can think of!
See below for all the specs to answer your questions.
Thanks for the help and advice to give me a bumping boat !!!
Sony CDXm60UI Specs
AM/FM Radio, CD, CD-R/RW, MP3/WMA, USB, iPod marine receiver
52 Watts x 4 peak power with three 2V RCA preamp outputs (rear, front, sub)
Detachable faceplate with two-line white LCD display; selectable red/blue illumination
Features MP3/WMA playback, direct iPod control, auxiliary input; ready for HD/SAT radio adapters
UV Resistant front panel coating and conformal coated circuit board
Infinity 612m Specifications
Power Handling, RMS: 75 Watts
Power Handling, Peak: 225 Watts
Sensitivity (2.83V @ 1m): 92dB
Frequency Response: 50Hz - 20kHz
Impedance: 4 Ohms
Mounting Depth: 2-5/8 inches
Polk EX Specifications
Sensitivity 92 dB at 1 watt
Frequency Response 75 - 22k Hz
RMS Power Range (Watts) 2-60
Peak Power Handling (Watts) 120
Impedance (Ohms)
Pioneer Sub Specs
10-inch, 4-ohm subwoofer with 1200 Watts peak (350 nominal) power handling
One-piece, seamless IMPP composite cone design for high power handling and accuracy
Dual-layer elastic polymer surround for added durability and lightness
Frequency response: 20 Hz to 280 Hz; Sensitivity: 92 dB
Available in single- or dual-voice-coil designs
JBL 4 channel amp Specs
Marinized circuit board
Stainless-steel hardware
Variable bass boost
12dB built-in variable electronic crossover
60W RMS x 4 channels at 4 ohms and 1% THD + N
MB Quart 6 channel amp specs
Power Rating: 6 x 120 watts at 4 ohms peak (6 x 60 watts RMS)
6 x 200 watts at 2 ohms peak (6 x 100 watts RMS)
3 x 400 watts at 4 ohms bridged peak (3 x 200 watts RMS) T.H.D: < 0.05% S/N Ratio: 93dB Input Sensitivity Range: 0.2V to 6.0V Channel Separation: 80dB Crossover Frequency (High- and Low-Pass: 40 - 250Hz Fuse: 70A x 1 Dimensions: 18 x 9.76 x 2.6 Inches (L x W x H)
Sony CDXm60UI Specs
Impedance: 4 Ohms
Impedance (Ohms)
Pioneer Sub Specs
Variable bass boost
