rockroussel
- Feb 14, 2013
- 2
I have twin tohatsu-2000, model m90a's , and after thirty minutes of open water runnning the max rpm falls to low to mid 4,000.
The starboard engine started doing this first then the head gasket failed. I have cleaned the tanks and changed the old fuel line from the tanks to the motor, and fuel seperators. I purchased the boat from Tampa and think there maybe some cooling(corrosion) issue which is causing the engine to go into some safety mode? no alarms come on but the bolts were so frozen on the head that we needed to torch them off. Any thoughts ??
Thanks John
Thanks John
