Michael-Searay
- Jun 23, 2012
- 30
Just replaced NGK BPR6EFS spark plugs on a 3.0L Mercruiser and noticed the one that came out of cylinder 4 has two cracks in the white insulator (from the top down) . The plug was very tight so my first thought is too much force on the wrong angle and I must have caused the damage while removing. However while test starting on muffs I am now getting a very distingtive fast knocking sound over 1400 revs. Oil level is OK, hesitant to test in the water to see if it is the same, in case there is some piston or valve problem???
Come to think of it, the boat did seem down on power and sluggish the last time out. Any advice?
Thanks, Michael
Thanks, Michael
