minuteman62-64
- Apr 12, 2011
- 1,350
1982 Mariner 30A. Replaced impeller a couple of months ago. About 3 hours on new impeller. Ran good at a steady 145 degree head temperature, good flow through tell-tale.
I run motor on muffs about once per month (maybe 15-20 minutes) just to make sure it is in running condition/ready to go. Last month I noticed it ran well at the start, then, when I was about to shut down, the tell-tale flow decreased and the head temperature increased to 180 degrees. I didn't think it was anything more than the hose supply pressure dropping, causing poor performance on the muffs.
This month I fired it up and there was no flow from the tell-tale. Started pulling things apart and squirting water in various locations. Flow through cooling circuits not a problem. Pulled the LU, removed the impeller housing and noticed the impeller was sliding on the shaft. Some rubber grains and smears in housing, but impeller still in good shape. I did notice the impeller fit very tightly in the housing.
I can reinstall the impeller with the key in the slot and it seems to work OK when I turn the drive shaft by hand. However, I'm concerned about how it came free.
Any ideas?
How can I determine if Crowley provided the correct diameter impeller? I can't find any specs.
Any ideas about what would make the impeller "jump" the shaft? Could it be too big in diameter so it turns too hard?
Any ideas?
