Re: Replace a stringer drive with a merc alpha 1?
empty the hull of the engine and drive. Use plywood and fiberglass to fill in transom cutout.
(consult this forum
Boat Restoration, Building, and Hull Repair )
Then you can use the Mercruiser installation manual to get dimensions for stringer height and distance from keel for making the new Merc keyhole cutout. The "X dimension" as it is often called will help you center the gimballed transom mount setup in the new transom at the proper height. The engine is then centered to that. (Engine crank centerline dead center of gimbal bearing)
If you currently have selectrim, you'll need fixed engine mounts from a Merc setup and the Y pipe for exhaust etc. as well as the obvious drive/transom assembly, and wood and glass stuff.
although this other Bayliner is VP powered, I suspect the pics in this thread would be quite useful for transom work and seeing how the bilge area of your boat is constructed:
http://forums.iboats.com/boat-resto...pr-1950i-volvo-penta-aq125a-resto-555694.html
