Re: Advantages/disadvantages of a tunnel hull
Tunnels are use specific for shallow water running like we have down here on the coast (Gulf of Mexico). They require specific amenities to achieve the desired result. I am just speculating having not had one but wishing I did when I fished down there. Seems they are hard to plane out without much transom to water surface area requiring a high HP engine to get up, then the engine would be required to sit lower in the water to get some clear water to run in and then sub standard performance when running across the bay to get home in a good chop. Seems a hydraulic jack plate would be a necessity to achieve both objectives.
If you are doing it just to be doing it, why worry. In reading sales brochures, the most successful seem to be with a curved (semicircle) top and vertical sides, not square/flat sides and top.
My 2c,
Mark
