96 mer cruser 5.7 burned piston
moparmanglhs
Im trying to find out what is wrong before i put this thing back together again. I hope someone can help. Eng. ran strong and idles smooth for several seasons then one day running it started hammering and pushing.oil out dipstick and breathers. pulled heads and found #6 piston burnt through. other pistons were fine. had eng. bored and rebuilt by eng.shop. reinstalled eng. and after about 8 hrs. on the eng. same thing happened to the same cyl. someone told me the thunderbolt v ign can cause this. Any one know of this problem ?
Don S
Re: 96 mer cruser 5.7 burned piston
Timing, running lean, water, hard to say without seeing the damage.
Ayuh,.... Welcome Aboard,.... My guess is, You've got a Detonation problem,....
A Lean condition caused by bad fuel is probably the #1 cause...
achris
More fish than mountain goat
or an overloaded engine... What rev did it make at full noise before the piston left the building?
If it was low grade fuel the knock sensor on the TB-V would have retarded the timing....
Chris.......
moparmanglhs
Thanks for any ideas or advice on this problem. The damage looks like it could be detonation but it only happened in one hole. #6 both times. makes me think it could be the ing. system firing that plug to early but Ive never heared of that happening to one cyl. Fuel was fresh both times out.
moparmanglhs
Chris.......
Thanks Chris. Nothing came apart. the piston began to melt and burn, molten alum. spatered cyl wall and head. we were running about 4200 to 4500 at the time
