Re: 65HP Merc idling to high and wont go into gear.
Okaye. Now we are after the shifter only (I guess). Disconnect the linkage at the engine. Manually move the shift arm (to which the shift linkage was connected, to the N position. Spin the prop in both directions where it should spin freely.
Carefully push the shift arm to the F position and as you do, wiggle the prop back and forth so that you can tell when the gears start to mesh. Mentally note the position and continue on with the shift lever till it will not move any farther. Grasp the prop again and attempt to turn it in both directions. In the CCW direction, it should resist to the point where you can stand on the prop blade and move the whole engine (crankshaft and all). Rotating in the CW direction yields a clicking sound and no powerhead movement. This is the overrun clutch working and if your engine responds to both directions as I said, your problem is your shift linkage from your control is out of adjustment.
If so, return the engine shift arm to the N position and wiggle it to ensure you are in the center of the N detent. Place the remote control shift/throttle lever in N and wiggle it to ensure it too is centered. Lay the hole in the end of your shift cable over the stud in your shift arm and look back up the cable to where the outer cable is terminated in a threaded brass area and see where your barrel is with respect to the slot it is supposed to fit into (in the engine).
I am expecting that in the current configuration, the barrel is not lined up with the slot (causing your problem). Spin the barrel up/down the threads till it lines up and install the cable ensuring both ends are locked in place.
Go through the shifting pattern you went through initially, but this time move the remote shift lever. If you get the same results, you are good to go. If not, you may have to drop the lower unit to line up the shift arm in the engine, to the shift cam in the LU. But then again, why are you having to go this far? What was the PO doing?
HTH,
Mark
